I'm having some issues using maptextlabeller :
- Labelling lines : labels are too far away from the lines. I tried to correct that with a maptextstyler. I found how to get them further but not closer.
- Labelling points : some of the labels are overcrossing lines. However, I don't allow overcrossing lines in the rules and I've also checked lines as obstacles.
Charlotte
