ArcGISAutomagicDocumenterServer
  • September 30, 2024
  • 0 replies
  • 24 views
fmelizard
Forum|alt.badge.img+21
FME Hub user martin_ekstrand just uploaded a new transformer to the FME Hub.
Uses the ArcGIS Server Rest API to list all services data sources (Enterprise and file geodatabase tables) and publish sources (APRX/MXD).
This transfomer is part of the ArcGISAutomagicDocumenter series. It is meant to be used together with the other transformers, but it can also be used on is own. It is meant to be used as an input for the ArcGISAutomagicDocumenterReportGenerator
Sample workflow for the ArcGISAutomagicDocumenter series can be found here
Would you like to know more? Click here to find out more details!
