I'm not sure of the significance of the error either. I plan to use the final geometry in a few energy simulations using Rhino and OpenStudio. Is it really necessary to fix non-planar polygons to run these simulations? I could use advice in this matter as well.
I have validated the GML data in the CityDoctor. It found the error "GE_P_NON_PLANAR_POLYGON_DISTANCE_PLANE" in nearly all of the buildings. Is there a way to fix such an error using FME?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
