Httpcaller Error
  • February 6, 2019
  • 167 views
ayraju
I am using the FME Httpcaller to get data from an API. There is an issue with the API and some of the calls are rejected with a 404 Not Found Error. I am using the Error logging option in the FME translation but i wish to exclude this particular error. Is there any way to exclude certain errors from being logged in the Error log in FME?
danilo_fme
Forum|alt.badge.img+53
  • February 7, 2019
  • February 7, 2019
On a general note, it may sometimes help slowing down the HTTP calls using the Decelerator transformer.
