Use a FeatureWriter to write the results. You then can use the attribute in the DataSet path. This can also be done using a classic writer, but I think the FeatureWriter is more intuitive.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
