Using dwgstyler in FME; I try to convert points from shp to dwg using a block for symbologie and I recieve this warning: Specified block 'C-E-TOP-NIV-PTC-SYM' is not defined in AutoCAD file. Skipping feature. Please advice!
Error writing blocks in Shape to DWG translation
