Hi all,
I have a set of JSON files which return an error upon trying to read them in - that it encounters an unexpected character "\\". If i open the JSON in a text editor and remove all the \\ characters it reads successfully in FME then.
As i have a batch of 300 JSON files i cant do this manually. I have tried reading in each one as a text file and using a StringReplacer but it is incredibly slow.
Has anyone got any suggestions or solutions?
Kind regards,
Jack
