why can't I write my aggregated lines into a polyline feayure class?
  • May 13, 2014
  • 157 views
Hello.
I have a searies of Lines coming from a FGDB polyline feature class and I have aggrated them into one polyline. When I then try and write this into another polyline feature class I can't. I can the error message "Cannot write a non-linear feature to a polyline feature class".
I've tried adding in a geometry coercer after the aggregator but this has no effect.
Hsa anyone experienced this before? Is there an alternative to aggrehator that works for lines?
Thanks
fmelizard
Forum|alt.badge.img+21
  • May 13, 2014
Are you sure you are writting only lines? I would place a GeometryFilter just before the writer.
You can also generate a workspace and FME will place the correct writers set to the geometry type found in the input.
gio
Forum|alt.badge.img+15
  • May 14, 2014
does'nt non-linear suggest somthing like an arc, spline and such?
You might want to filter prior to writing to restrictive shape file.
  • May 14, 2014
I've tried using a geometry filter this morning and everything came out as a line.
Perhaps even more bizarre is that I've dissolved the input features in ArcGIS and loaded them into the feature class fine, so there cant be a problem with the lines.
fmelizard
  • May 14, 2014
not necessarly, since FME will work on the fully decimal accuracy, while ESRI doesnt, try to round the coordinates decimal places before writting.
