Hello
Following situation: Via HTTP-Caller I send a POST. Via the normal way, when I send the POST via a REST-Editor (Postman) then I got a response in JSON-Format with an URL, which I click it downloaded a zip-File with the data. My first question: How I catch in the HTTP-Caller the response? Or is a option to trigger immediately the download of the zipFile?
Thanks
You should be getting the JSON response in the "_response_body" attribute from the HTTPCaller:
From there on you can use e.g. the JSONFlattener to extract the URL into an attribute, then another HTTPCaller set to download the zip from that URL:
This article contains a lot of great information on how to work with APIs using the HTTPCaller, if you haven't seen it already:
https://knowledge.safe.com/articles/92720/how-to-access-an-api-using-the-httpcaller.html
Thanks a lot for your precious answer
