I am trying to set the Writer Destination folder to dynamically or automatically set to the location of the Reader Source folder but I am not having much luck.
I thought the easiest approach would be to use the FilenamePartExtractor and set the _dirpath as the attribute value or user parameter of the Destination folder but it doesn't work.
Does anyone know the best way to set these parameters in FME?
Thanks
Andrew
