I have noticed that some (not all) points receive the Format Attribute named mapinfo_type from the region dataset even if this attribute is not exposed in the Reader.
Then, if I want to write the points in a MapInfo TAB writer, the writer is confuse because it consider those points as area and cannot write it down because there is only 1 vertex in the feature.
Is it normal (I dont think so) that the pointOnAreaOverlayer pass the Format Attributes of the features to the other? It's even more weird that only some points receive this format attribute.
Can someone help me with this issue?
