Method to mirror a shape object?
  • June 17, 2013
  • 101 views
I'm currently trying to create a mirror copy of a set of rectangles. Each rectangle needs to be mirror on one particular side to create its other half.
So far, my method has been to identify a centerpoint on the side I want inorder to use rotater transformer, but I've had limited luck getting the procedure working in the correct order when I attempt to aggregate the original rectangles with the centrepoint.
Are there any other methods or transformers I  could potentionally use?
Forum|alt.badge.img+4
  • June 17, 2013
If i'm reading this correctly, you want to clone a rectangle and offset it by its width/length so that it forms a square?
If so, I believe the following would work - in theory:
  • Get centrepoint
  • Locate distance you want to shift the rectangle
    • Potentially via GeometryCoercer to make area to line
    • Chopper to chop into 2 vertex lines
    • LengthCalculator
    • Sorter -> Sampler to find shortest length
  • Locate angle you want to shift the rectangle
  • Cloner to duplicate original rectangle. (Emphasis on original)
  • Offsetter to offset cloned rectangle by distance and angle.
  • June 18, 2013
Thanks for the response.
The final solution implemented was:
-TopologyBuilder instead of GeometryCoercer to break down the polygon. (GeometryCoercer couldn't change to lines for some reason)
-SpatialFilter to pick the right line which crosses a seperate reference box.
-CenterOfGravity replacer on spatial filter results.
-coordinateExtractor.
-Then I had to use featureHolder for the next step of combining the reference point and the original source
-Aggregator with a grouping based on an attribute part of the polygons and point.
-Rotater with 180degrees and attirbutes X/Y points refering to the previous coordinateExtrator.
Viola.
