what does mean _cell_origin_x 0.5 in raster information
  • March 14, 2013
  • 15 views
Does some people know what does mean _cell_origin_x = 0.5 in raster information?
This is not the pixel size because the pixel size of my image is 0.2.
Thank for your help
fmelizard
Forum|alt.badge.img+21
  • March 14, 2013
The pdf from this article explains most of the FME terms use with rasters, the _x_spacing and _y_spacing correspond to pixel size.
Hope this helps
Forum|alt.badge.img+4
  • March 15, 2013
Directly from the FME Advanced Course:
Raster Origins and Extents For an entire raster dataset, the origin point is the upper left corner (A). The extents of a raster are the lower left X and Y of the lower left cell, to the upper right X and Y of the upper right cell (B) . For individual cells, 0.0, 0.0 is the lower left corner of the cell, and 1.0, 1.0 is the upper right corner. The origin point is usually the cell centre; 0.5, 0.5 (C). This is the cell origin that FME uses.
There's a pretty picture accompanying the description too but I hope this by itself helps.
  • March 15, 2013
Thanks Itay and Kathy for your answer
