Subtracting two unknown values from each other
  • July 20, 2017
  • 78 views
Hello there,
I'm having a difficult time with subtracting two unknown measurements of line features with each other.
In short, I'm calculating the lengths of two overlaying features (lay1 and Lay2), and I want to check for all values that when subtracted from each other, is smaller than 5.
Everything is working perfectly, except where I'm stuck, is in a tester transformer where I added the following (seemingly incorrect) info in:
@Value(Lay1_Length)-@Value(Lay2-Length) > 5
Is there a different way I should create this expression?
Kind Regards,
Best answer by ebygomm
Make sure you are in the Arithmetic editor not the text editor. Your left value in the tester should look something like this
@Evaluate(@Value(lay1_length)-@Value(lay2_length))
Forum|alt.badge.img+46
  • July 20, 2017
  • July 20, 2017
Another check point. Does a single feature have both Lay1_Length and Lay2_Length attributes?
Hi @egomm
This did indeed solve my problem, thanks a lot!
Cheers,
