Hi all, I want to create a shorter name of an attribute values for example attribute values name is building but i want when i type it in arcgis as build it should reflect as building in suggestion name. Can anyone help me that how i can do that in F
How to make a shorter name of a full name in FME as when i type the short the full name will come under suggestion
sigtill
Forum|alt.badge.img+24
  • October 23, 2019
Have a look at the AttributeManager
bruceharold
Forum|alt.badge.img+17
  • October 23, 2019
Maybe you want to write attribute alias names? Sounds like a good writer enhancement idea.
