Problem with SQL server connection in translation
  • December 23, 2013
  • 13 views
I have a translation that is taking a shp file and inputting it to SQL Server.  I can create the writer, but during the translation I get an error saying that
MS SQL Server (Spatial) Writer: Connection Failed.  Connection string 'Provider=SQLOLEDB;Data Source=srv-onscene-tes
Provider error '(-2147467259) [DBNETLIB] [ConnectionOpen (Connect(().] SQL server does not exist or access denied.
Any suggestions would be helpful.
Thank you,
Joan
fmelizard
Forum|alt.badge.img+21
  • December 26, 2013
Hi Joan
When you add the writer it does not really check that the credentials are valid so here are few things to check:
1. In the navigator on the left check the user name, password and server name are all correct
2. Assuming you have a destination feature type already (which represents a destination table)  double click on it to get the properties and then go to General tab and check that the user is set to a user with access to the table you want to write to. Here is a screen shot that might help.
