Shapefile to WKT
I have a line shapefile, can I convert this to a csv file displaying a column of well-known text?
Best answer by david_r
You can use the GeometryExtractor set to OGC Well-Known Text.
  • August 20, 2018
  • August 20, 2018
Thanks @david_r,
I was going to ask how to do the reverse, @DebbiAtSafe kindly pointed me in the direction of using GeometryReplacer - https://www.safe.com/transformers/geometry-replacer/.
