How to combine attributes when there is nothing to join on
michael_m
Participant
Hello,
I am working to pull information from autocad block attributes and need help overcoming a problem. Currently, each block's attributes have their own record in the table I am writing them to (they are organized this way straight out of the DWG reader). Looks like this:
Attribute1Attribute2Attribute3<Null>AB<Null>CDE<Null><Null>
What I want to do is combine the records somehow so the table looks like this:
Attribute1Attribute2Attribute3EAB
E
CD
Any ideas how I can do this? I have tried FeatureMerger and InlineQuerier but have had no luck because there is nothing to join on.
Thanks,
Mike
*EDIT*
Initially in the DWG reader I was Grouping Entities by Attribute Schema. I just tried grouping them by Layer and got the same results.
erik_jan
Forum|alt.badge.img+17
  • May 12, 2016
Have you tried the FeatureMerger, not based on attributes but on actual values (1 = 1)?
michael_m
Participant
  • Participant
  • May 12, 2016
I added a common attribute to each set with attribute creators and was then able to use FeatureMerger on them to do what I wanted.
Is that what you had in mind?
erik_jan
  • May 12, 2016
Even simpler than that:
michael_m
Participant
  • Participant
  • May 12, 2016
That did it! Thanks @erik_jan
