Hello everyone,
I use PBF data format as a reader. Which I downloaded from https://planet.openstreetmap.org/pbf/ or any other URL and Esri Geodatabase (File Geodb API) format as a writer.
Is it any possibility that the reader takes the LATEST VERSION pbf file automatically from the website and After that the writer show the date of used pbf file (which date of pbf file was used)?
For example: I took the pbf file of (2018-01-11) in reader and the writer shows the same date (2018-01-11) data is used for reader.
Thanks.
