How to extract Z values from start and end vertex of DWG to an attribute.
  • October 21, 2013
  • 57 views
I am trying to to extract Z values from the start and end vertex of 3d polyline in Autocad to an attribute. Should be fairly simple but all the trasformers i have tried failed? Thank you
  • October 21, 2013
I will need the start and end (2 total attributes).  thank you
  • October 21, 2013
The CoordinateExtractor transformer can be used to extract coordinates of a vertex at specified index.
Use two CoordinateExtractors in a series; one for start (index = 0), another for end (index = -1).
Takashi
