How do i compare data rows from two tables accross two databases?
  • September 24, 2019
  • 5 views
How do i compare data row count from two tables across two databases? Basically i am trying to load data if source has more rows than target table.
danilo_fme
Forum|alt.badge.img+45
Hi @rajan
Did you try to use the transformer FeatureMerger to compare?
Thanks in Advance,
Danilo
erik_jan
Forum|alt.badge.img+18
I created a workspace (without the data) that shows the workflow:
Hope this helps.
Thanks a lot for 1=1 trick was getting two separate rows and that was chocking point.
