I need to extract lines from polygon
  • February 26, 2019
  • 7 replies
  • 126 views
checcosisani
Forum|alt.badge.img+12
Hi All
there are some discussion about centerline replacer
I've tried to run to extract centerline of a poligons (taht represent roads) but I received
2019-02-26 13:45:14| 2.2| 0.5|WARN |CenterLineReplacer: Unable to prepare geometry for skeleton construction
2019-02-26 13:45:14| 2.3| 0.1|WARN |CenterLineReplacer: Unable to prepare geometry for skeleton construction
So can you suggest the correct workflow to obtai9n tjhe centerlineS ?
thx
Francesco
fmelizard
Forum|alt.badge.img+18
  • February 26, 2019
Hi @checcosisani Try the new 'Approximate Center Line' mode, available in FME 2019 betas - www.safe.com/beta
itay
Forum|alt.badge.img+17
  • February 26, 2019
HI @checcosisani,
The calculation of a center line can take up a lot of time, depending on the feature complexity (e.i. the number of vertices) using a Generalizer transformer can help speed up the process.
Hope this helps,
Itay
checcosisani
  • February 26, 2019
itay wrote:
HI @checcosisani,
Hope this helps,
Itay
Hy Itay
done with 5m
which settings you suggest ?
thx
Francesco
checcosisani
  • February 27, 2019
Hy Dan
thx for suggestion !
Amazing tool !
one question how I can try to avoid situations like this (see bmp)
Thx
Francesco
fmelizard
  • February 27, 2019
checcosisani wrote:
Hy Dan
Amazing tool !
Thx
Francesco
Hi @checcosisani That looks bad :( I assume you're displaying the coordinates on the lines? We're still making refinements to this approximate mode. Can you send us your source data via https://www.safe.com/support/report-a-problem/ ? Thanks!
itay
  • February 27, 2019
checcosisani wrote:
Hy Itay
done with 5m
thx
Francesco
Hi @checcosisani,
Any settings that don't distort the original shape of the objects but reduce the number of vertices would help, so the any of the Generalizing algorithms should do the trick.
Itay
itay
  • February 27, 2019
checcosisani wrote:
Hy Dan
Amazing tool !
Thx
Francesco
From the looks of it a Dissolver might help.
