How to merge more than one line that intersected in one point
soly
Forum|alt.badge.img+3
i used linecombiner transformer but it is able only to connect two lines but i have sometiems 3 or 5 lines are connected so which transformer should i use .Thanks
  • January 31, 2020
You can use the Aggregator for this.
  • January 31, 2020
@soly can you include a small example data set or image of what you what to accomplish?
soly
  • January 31, 2020
thanks
so should i put aggregator at the end and it will solve this problem as ur suggestion ,could please tell me which parameter should i do for aggregator and thanks alot
