XMLTemplater listattributes
Hi everyone,
I don't know how to work with listattributes inside the XMLTemplater Transformer.
A feature contains a list networks.network{}, foreach element in the list, I want to create a new child element "networkNode".
Do I have to loop threw the elements and create the xml for each, or is it possible to do it directly in the XMLTemplater?
networks.network{0}.type = type0
networks.network{0}.linkage = linkage0
networks.network{1}.type = type1
networks.network{1}.linkage= linkage1
What I want my XML to look like:
<OnlineContact>
  <aixm:networkNode>
            <aixm:network>type0</aixm:network>
            <aixm:linkage>linkage0</aixm:linkage>
         </aixm:OnlineContact>
     </aixm:networkNode>
    <aixm:networkNode>
            <aixm:network>type1</aixm:network>
            <aixm:linkage>linkage1</aixm:linkage>
     </aixm:networkNode>
</OnlineContact>
I am using FME Desktop 2015
Thanks, Mel
Best answer by kim
One possibility is to use a ListExploder on the list, then add them into the XmlTemplater using a Sub template.
I've included a sample that I believe achieves what you are trying to do in the workspace below:
Forum|alt.badge.img+5
  • March 4, 2016
  • March 4, 2016
Thanks, it does exactly what I want :)
