We have just upgraded our 2017.0 to 2017.1.1.1 server and restored backup. We previously configured https on this machine. Anyone know if you can reuse the certificate on the same server? I would think that if I pasted the keystone file into the directory and made all the changes to the tomcat xml files it would work? Once I completed the FME Server Application Service would not startup and https isn't working? Any thought?
