add new empty line in text file specific location
Trying to figure out how to add an empty line (commas are fine) into a file at specific locations
here is an example i need:
10-1110011-1220012-1310013-14400
Any thoughts?
Regards
  • July 3, 2018
What is the criteria to determine where an empty line should be added?
  • July 3, 2018
the above example is time based so where it moves from AM to PM a break in the data for easy readability is required.
Thanks
  • July 3, 2018
Hi @fme_it, there should be several ways. Just an example.
Set the runtime order at the Passed port appropriately (first to AttibuteCreator, second to Junction).
  • July 3, 2018
Thanks for the suggestion. It almost works, occasionally it comes out before the line but only once or twice.
Regards
  • July 3, 2018
fme_it wrote:
Regards
I think that the workflow inserts an empty line before every text that starts with "12". Wasn't it what you needed?
