Iam attempting to write data using dynaminc schema in a workspace, it fails with the following warning:
Unexpected execution path. Please contact Safe Software
... Last line repeated 2 times ...
I am writing to ESRI geodatabase feature classes. When i disable the writers and run the workspace, everything works as it should do. I have used dynamic schema before succesfully and have tried many different variations of parameter setting but to no avail.
Any help much appreciated!
Thanks,
Chris.
