Hello,
I'm working with over a hundred huge non overlapping geotiff's (512 Mb each) where the band 0 value represents the height. I also have some polygons, which sometimes overlap multiple geotiffs. I would like to compute the maximum height from the geotiffs within that polygon and I would like to replace that part of the geotiff with this maximum height.
I managed to compute the maximum height so I created a shapefile with the polygons and the maximum height as an attribute and I also managed to create a Geotiff for eacht polygon with the maximum height as the band value.
Now I would like to get the last part of the job done: replace parts the original Geotiff whith the new geotiffs. I'm not sure how this could be done so any help is appreciated.
Arno
