Python Script - Overwriting records
  • June 6, 2019
  • 6 replies
  • 24 views
dataninja
name = feature.getAttribute('Chain')
query = {'Name': name}
params = {'query': json.dumps(query), 'fields': 'Name,Id', "OrderBy": "Name", 'limit': 5}
r = requests.get('https://location.chainxy.com/api/Chains', params=params, headers=headers)
for whatever in json.loads(r.content)['Records']:
<space> chainid = whatever['Id']
<space> chainname = whatever['Name']
<space> feature.setAttribute('CXY Name', chainname)
<space> feature.setAttribute('CXY Id', chainid)
Let's say that my list has three items and I expect my output to be as the following but apparently, my for loop is overwriting my record so I only end up with one record instead of three. How can I fix this problem?
Expected Output
Record ID --- CXY Name --- CXY Id
1 --- Hello --- 87
1 --- Hi --- 88
1 --- Nice --- 100
Actual Output
Record ID CXY Name CXY Id
1 Nice 100
daveatsafe
Forum|alt.badge.img+20
  • June 6, 2019
Hi @trungn1993,
Do you want to create a new feature for each record, or do you you want to create list attributes on the feature?
dataninja
  • June 6, 2019
Hi @trungn1993,
How about both :)?
daveatsafe
  • June 6, 2019
How about both :)?
Different processes for each.
dataninja
  • June 6, 2019
I want to create list attributes on the feature.
Forum|alt.badge.img+46
  • June 6, 2019
This is the one way you can create a list on an attribute
import fme
import fmeobjects
def processFeature(feature):
    list = ['apple','banana','pear']
    for i, val in enumerate(list):
        feature.setAttribute('list{'+str(i)+'}.fruit',val)
Don't forget to enter the list attribute in the python caller under Attributes to Expose
  • June 7, 2019
In addition to the reply by @egomm, here's a solution for creating one feature for each element in a Python list:
import fme
import fmeobjects
class processFeature(object):
    def input(self, feature):
            new_feature = feature.clone()
            new_feature.setAttribute('list_value', val)
            self.pyoutput(new_feature)
This will create a copy of the incoming feature(s) for each element in the list, adding a new attribute "list_value".
