Extract table name and primary key within database
  • June 27, 2019
  • 225 views
boubcher
Forum|alt.badge.img+11
Hello there
I am looking to extract tables name and primary keys of a database in order to use it on the other workspace
Any idea, please
mark2atsafe
Forum|alt.badge.img+59
I don't know if you want to automate this or just get a list, but databases usually include a system table that lists all user tables.
For example in SQL Server this command should return a list of tables:
SELECT TABLE_NAME
FROM <DATABASE_NAME>.INFORMATION_SCHEMA.TABLES
WHERE TABLE_TYPE = 'BASE TABLE'
You could put that into FME in a SQLCreator transformer, and then you'll get a list of tables each as a separate FME feature.
I don't know what else is stored in that table, but I expect primary key would be another piece of available information.
