FTP wildcard filename
  • January 30, 2019
  • 107 views
Hello. Does anyone know a solution on how to grab a file from FTP using wildcard along the lines of filename*.txt
We receive a daily file drop to our FTP with a timestamp attached to the end of the filename. It would be helpful if we can set up a workspace that grabs the file using partial filename only. This wildcard works for the folders on a local machines, but does not work for us on an FTP.
Any helps will be greatly appreciated.
danilo_fme
Forum|alt.badge.img+53
  • January 31, 2019
  • February 4, 2019
Understood. Thank you for your help
