How to publish a new ArcGIS Online Feature Service with attachments
  • November 5, 2025
  • 0 replies
  • 47 views
mgg_beca
Forum|alt.badge.img+17
I’d like to read a folder of documents and a set of points (say from a csv) and then join these together (filename of documents might match an attribute on the points), then write them all to an ArcGIS Online feature service with the documents as attachments.  I would ideally like to do this in one workspace and not have to hardcode anything.
I don’t think this is possible without using one workspace to write the CSV to feature service, and then another to read it and add attachments using the ArcGISAttachmentCOnnector, as that requires the feature service URL, which may not be known at the time of creating the feature service.
Thanks,
Marc
