No longer have ability to view lists with attributes
  • November 3, 2025
  • 26 views
dmesler
Participant
I have an odd problem. I have suddenly lost the ability to view the lists on my objects in the “feature information” pane. They are indeed there, I can search and explode them, but for some reason -mid working on this workbench- I have suddenly lost the ability to see my lists.
I am in version 2024.2. I havent found anything helpful or related online yet so thank you if anyone is able to assist.
created list ^
no list visible ^
I am ONLY able to see the lists in the “Found” port of a list searcher, but in NO other occasions can I see them.
j.botterill
Forum|alt.badge.img+55
  • November 4, 2025
I feel the feature cache might have become stale. If you look up more about caching, you’ll find that the order matters. A partial run is where you have green inspection ports you can trust but if you may a change the following transformers will be stale or yellow in colour.
https://fme.safe.com/blog/2018/05/caching-data-fme-evangelist174/
Try an “entire run” and inspect the transformers for your list. Ensure they are all green in colour
