FME Change Log Detailed Description - Workspace Parameters
  • May 23, 2025
  • 72 views
mackinneyjg
Hi
I was particualrly interested in an item that is mentioned in the FME Form Change log for FME 2025.0.2 - “Add support to read workspace parameters.”
https://fme.safe.com/changelog/?_change_log_product=FMEFORM&_change_log_version=2022000001%2C2025000200
I was wondering if it is possible to obtain a detailed description of what this change is? It may well address a topic that I have been interested in for some time.
Regards
Jamie
alexbiz
Forum|alt.badge.img+31
  • May 23, 2025
Is there anything specific you want to know about it?
Here's what it looks like:
mackinneyjg
  • June 4, 2025
Apologies for the late reply ​@alexbiz. Thanks for that information, that clarifies things. I was hopeful that the change might be related to a previous question from ​@tb09114 :
I would like to have my choice parameter options being sourced from a database table than hard-coded options that you need to maintain in the workspace itself. I though that the above change might be related to that request/discussion.
