Generate incrementation from column max value
  • April 19, 2024
  • 45 views
user01
Hello,
I want to generate an incrementation from the max value of a column in order to not have duplicate values. The _max value column is not recovered in the counter for the 50 duplicate features :
Any idea ?
Thank you
Best answer by jasperwis
Looks like you need to merge the _max value from the ListRangeExtractor with the Duplicate features before going to the Counter.
Jasper
jasperwis
Forum|alt.badge.img+19
  • April 19, 2024
Jasper
