Released
Update Coordinate System Definitions to convert between FME Coordinate System Re
Related products:FME Form
  • April 15, 2019
  • 7 views
***Note from Migration:***
Original Title was: Update Coordinate System Definitions to convert between FME Coordinate System Representation and EPSG Number without omission
In FME 2019.0, there still are some FME coordinate systems that cannot be converted to EPSG number with the CoordinateSystemDescriptionConverter, vice versa.
e.g. LL-JGD2011_FME (EPSG:6668), JGD2011-09_FME (EPSG:6677), etc.
I'm waiting for the update for a long time. Hope it will be improved as soon as possible.
Thanks in advance.
paul.nalos
  • November 15, 2022
@Takashi Iijima​ This is a very belated message, but I believe the mappings you were hoping for were part of FME as far back as FME 2019.2.3. If there are still gaps that concern you, please let us know.
