Direction of a closed curve (line)?
  • May 19, 2017
  • 54 views
ireen
Forum|alt.badge.img+5
I have to determine the direction of a closed curve (a line where start and endpoint are the same) because I want to derive a gpx in the right direction (clockwise) from the polyline. Is there a way to do this?
So I want to test if the polyline has a clockwise direction and, if not, reverse the direction.
I tried the Polylineanalyzer and the azimuthcalculator, but both don't give me a solution.
Best answer by takashi
Hi @ireen, I would try this.
  1. LineCloser: Transform the curve to an area.
  2. OrientationExtractor: Extract the orientation of the area.
  3. GeometryCoercer (Geometry Type: fme_line): Restore the original curve.
Note that the orientation may not be extracted correctly when the curve has self-intersections.
jdh
Forum|alt.badge.img+40
  • May 19, 2017
Have you looked at the OrientationExtractor or Orientor?
ireen
  • May 19, 2017
Yes, I did, but both only work on areas, not on line features.
  • May 19, 2017
ireen
  • May 20, 2017
Thanks a lot; this works fine!
