Do anyone know how to make a ortofoto brighter? The ortofoto I am currently working on is a bit to "dark" lake it`s taken in the evening.
  • September 17, 2021
  • 19 views
caracadrian
Forum|alt.badge.img+23
Try RGBBrightnessContrastAdjuster from the FME Hub
Thank you :)
If you want to learn more about manipulating raster pixel values yourself, I'd recommend starting at this very helpful article that demonstrates several use cases for the RasterExpressionEvaluator: https://community.safe.com/s/article/simple-examples-using-the-rasterexpressionevaluato
