3D Intersect between 3D line and Solid
  • May 18, 2021
  • 8 replies
  • 356 views
canerakin
I am trying to intersect 3D Polylines and Solid Cubes to determine which cubes are touching the polylines.
So far I tried Clipper, intersector, SpatialRelator and SurfaceOnSurfaceOverlay. All the features are ending in the rejected port as invalid geometry.
What is the right way to accomplish this task?
Best answer by daveatsafe
Hi @canerakin​,
We are working on improving FME's 3D intersecting capabilities to include surface features, but at present only solid and point cloud geometries are supported. However, using a little geometry transformation, I think we can get the answers you are looking for.
The attached workspace densifies the lines and converts them into linear point clouds, then clips by the cubes to transfer their attributes onto the appropriate lines.
Screen Shot 2021-05-31 at 2.17.02 PMPlease try the workspace to see it produces the results you need.
canerakin
  • May 18, 2021
I was able to complete this with "Select by Location" in ArcPro using 3D Intersect. However it would be great if there is a way to do this in FME instead of using Arcpy/ArcPro.
canerakin
  • May 22, 2021
Any help with this question?
caracadrian
Forum|alt.badge.img+23
  • May 24, 2021
There is a workaround for this in FME that works for simple 3D shapes.
You intersect the lines with the hull of the shape in every plane (XY, XZ, YZ) do some aggregation and test for the number of planes in witch it intersects a shape (cube).
If it is equal to 3 it intersects the cube you are testing for and you get the cube ID.
I attached a sample workspace (thanks for the sample data 😀) that does this. I created UUID's both for cubes and for lines so i can work faster, you can ditch UUIDGenerators and replace your own ID's in the SpatialRelators attributes to add to the list and Aggregator, if there are any.
canerakin
  • May 25, 2021
Hi @caracadrian​,
This should not be complex that much.
Is there any other easy way? @david_r​ @Takashi Iijima​ @Mark Stoakes​ @ebygomm​  @daveatsafe​
  • May 27, 2021
Perhaps contacting Safe support could give you some additional answers. If the functionality isn't available or doesn't work as intended, I'm sure Safe would like to know about it.
canerakin
  • May 27, 2021
Hi David,
Thanks for the suggestion. I just opened a case.
daveatsafe
Forum|alt.badge.img+20
  • May 31, 2021
Hi @canerakin​,
mgg_beca
Forum|alt.badge.img+17
  • June 25, 2025
In case anyone else has this question, I was able to convert IFC surfaces to solids, and use the clipper to clip 3d lines where they intersected the different solids and transfer the attributes from the solids.
So this works now with lines.
Marc
