creating geometry
curtisd54
Forum|alt.badge.img+4
I need to create geometry for records which were merged with other data.
records with Geometry from SHAPE.STLength - below
records with no Geometry from SHAPE.STLength - above
This is the process with the transformers at the top is where the geometry records are not showing up after they were merged with supplier data
Forum|alt.badge.img+48
Can you share a bigger screenshot of your workspace? It's really hard to make out what's going on. Also a bit of background information (like source data formats) would really help us come up with suggestions.
curtisd54
  • June 11, 2020
the data is in a ESRI shapefile format, I have included a larger image
fmelizard
Forum|alt.badge.img+17
  • June 11, 2020
Hi @curtisshane In the FeatureMerger is the "Feature Merge Type" parameter set to "Geometry" or "Attributes and Geometry"?
