I've got a question about the webmaptiler transformer.
I'm trying to generate tiles for a Google Maps API map but the numbering in output does not match to what I expect. I read the doc and tested the different attributes fanout, the different schemes, but I'm still stuck...
I expect that (generated with QGIS) :
But I get only
Any idea how to do ?
Thank you from France for your help
