HttpCaller: send POST and then problems writing download stream to zip file
  • May 30, 2016
  • 10 replies
  • 63 views
peteralstorp
Forum|alt.badge.img+7
Hello FME-community.
I'm having trouble downloading data with the HttpCaller to a zip file.
1. First I upload text/xml below with a file key to say which file I want to download. See image .
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
  <soap:Body>
    <GetOrder xmlns="http://Vagverket.VIS.Lastkajen.LastkajenLogistics">
      <orderKey>@Value(FileKey)</orderKey>
    </GetOrder>
  </soap:Body>
</soap:Envelope>
2. I then receive (according to the data download specification) a download stream in base64Binary, see example below.
  <soap:Body>
    <GetOrderResponse xmlns="http://Vagverket.VIS.Lastkajen.LastkajenLogistics">
      <GetOrderResult>base64Binary</GetOrderResult>
    </GetOrderResponse>
  </soap:Body>
</soap:Envelope>
3. I use the XMLFlattener to filter out GetOrderResult, BUT I can't seem to get the download stream into a proper functional zip file. I have tried numerous ways (writing to a file directly from the httpcaller, using the datafile-writer and the attributewriter but I just can't make it work).
GetOrderResult (base64Binary) follows. This data contains, if I'm correct, a zip file containing a shape file TESTNVDB_DKC_Cykelled.shp (the file contains zero objects), a dbf file TESTNVDB_DKC_Cykelled_domainmap.dbf and a text file.
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
Any suggestions helping me out here are welcome.
Kind regards,
Peter
  • May 31, 2016
Hi @peteralstorp, did you try saving the response into a file by the HTTPCaller with setting File to the 'Save Response Body To' parameter?
peteralstorp
  • May 31, 2016
Thanks, takashi. Yes I did. I figure it must be a character encoding problem or maybe I need to understand the zip format better.
  • May 31, 2016
I think you can read the zip file with a FeatureReader following to the HTTPCaller, once you have saved it into the disk. Have you tried this?
peteralstorp
  • May 31, 2016
I think the zip file is the problem. I tried your suggestion (although I need to pass an xml-transformer to get rid of some xml-code. See image. takashi.png. The featurereader will not accept the zipfile.
  • May 31, 2016
How about setting fme-binary to the 'Target File Character Encoding' parameter of the AttributeFileWriter?
peteralstorp
  • May 31, 2016
Tried it but no. The zip file can't be read properly. Error msg: Error status STK_FAILURE pending -- message is: Error while processing folders
  • May 31, 2016
Well, the TextDecoder might help you to decode the Base64 string to an fme-binary string before writing.
  • Encoding Type: Base64
  • Character Encoding for Binary Data: Binary (fme-binary)
peteralstorp
  • May 31, 2016
Hm, still no readable zip file. Thanks for your efforts so far, Takashi!
  • May 31, 2016
I was able to read your sample Base64 string as a zipped Shepfile dataset. See the attachment: base64-to-fme-binary.fmw (FME 2016.1)
peteralstorp
  • May 31, 2016
Takashi, you are the king! Thank you kindly. I can't yet see what you did different than me, but there must be something!
