Calculate delta distance between two points
  • January 16, 2019
  • 5 replies
  • 107 views
geo-x
Dear FME community.
I try to calculate distance between a suit of points like that :
For that I make a sorter > counter and I try an AttributeCreator without success.
Have you got an idea ?
Thanks for your help
Forum|alt.badge.img+46
  • January 16, 2019
In your example, the distance between 2 & 3 isn't 10....
If you know the formula to calculate distances between coordinates then look at the adjacent attribute handling in the attributecreator. This will allow you to reference the the coordinates of the adjacent feature in the expression
geo-x
  • January 16, 2019
Dear @egomm, thanks for your response.
This is an example with fictive distances, but this is the global idea :-)
  • January 16, 2019
Did you look at Adjacent Feature Attributes?
  • January 16, 2019
  • January 16, 2019
Agree. Alternatively, the @hypot function can be used. cf. Math Functions
