SHA-256 hashcode
  • July 30, 2015
  • 5 replies
  • 362 views
fmelizard
Forum|alt.badge.img+21
Hi all,
Does anybody have some experience in creating a SHA-256 hashcode via FME (desktop/server)? or in combination with third party software?
Best answer by david_r
Hi
Its rather easy to do with Python's built-in hashlib module (https://docs.python.org/2/library/hashlib.html), something like:
import hashlib
hash = hashlib.sha256()
hash.update('Lorem ipsum')
hash.update('dolor sit amet')
print hash.hexdigest()
David
  • July 30, 2015
Hi
import hashlib
David
fmelizard
  • July 30, 2015
Hi David,
Thanks for the tip, looks promising.
Itay
fmelizard
  • August 1, 2015
Yep it did the trick, thanks!
  • January 26, 2017
I found this question, when I was looking for something similar.
I am quite unfamiliar with Python and therefor am struggling with my solution. So far I came up with this:
import fme
import fmeobjects
import hashlib
def processFeature(feature):
    strOld = feature.getAttribute('inputstring')
    hash.update(strOld)
    strNew = hash.hexdigest()
    feature.setattribute('hashcode', strNew)
Unfortunately, this leads to an errormessagePythonFactory failed to load python symbol `ProcessFeature'
Factory proxy not initialized
f_23(PythonFactory): PythonFactory failed to process feature
A fatal error has occurred. Check the logfile above for details
Bridge failed to output feature on tag `PYOUTPUT'
f_7(PythonFactory): PythonFactory failed to process feature
Help is appreciated, thanks in advance!Steven
  • January 26, 2017
Ha,
it seems to be about the casing in setAttribute...
Works now!
import fme
import fmeobjects
import hashlib
    hash.update(strOld)
    # hash_object = hashlib.sha256(strOld.encode())
    att = 'hashcode'
    feature.setAttribute(att, strNew)
