Using fme pathreader in fme flow apps
  • January 15, 2025
  • 11 replies
  • 226 views
keller
Forum|alt.badge.img+7
Maybe someone has experienced this before, i have been trying to make an workspace App in fme FLOW 2023, the goal is to make an app where the user can choose the source file. I have tried creating the App but it does not allow the user to choose the file location.
does someone have an idea what i may be missing out? I am using the FME PATH reader.
Thanks,
Keller.
Best answer by alexbiz
Most web browsers don’t support uploading a folder. You have to zip it if you want to send an entire folder.
liamfez
Forum|alt.badge.img+44
  • January 15, 2025
You can create a File/Folder/URL User Parameter (make sure it is a published parameter) in the workspace and use that to define the reader’s source path, before publishing to Flow. This should enable you to select files from the resources available to Flow or upload a file.
The Path Reader will read in a folder with the files and folders contained within it becoming features. If you actually want a file read in, you will want the appropriate Reader/FeatureReader for that file type.
keller
  • April 14, 2025
@liamfez the idea was to allow the user to select a folder, which works well in fme form, but in fme flow apps this option is not possible i guess. I am using fme2024. Any idea where i could be going wrong? And you are right after the path reader i use an appropriate reader to further process my input.
Thanks in advance
Keller.
Forum|alt.badge.img+46
  • April 14, 2025
So you’ve expanded the parameters option and ticked show in app, and the option to select a folder isn’t available via the app url?
keller
  • April 14, 2025
This is how my app looks like,
pic.1 .
then when i click on browse resources i get this page,
so i cant actually select any folder from my local computer.
  • April 14, 2025
Hi ​@keller ,
Likely the owner of the app (user who created the app) doesn't have permission to access Resources. Check the permissions of the user.
keller
  • April 14, 2025
@takashi ​@ebygomm  i was hoping by clicking browse reasources, i would get the option to browser to the local folders in my laptop and not the resources folder in the fme server. This works just fine in fme form.
geomancer
Forum|alt.badge.img+60
  • April 14, 2025
From https://support.safe.com/hc/en-us/articles/25407748431501-FME-Flow-Troubleshooting-Flow-Apps:
Problem: “My app has a file/URL parameter that is visible, but users don’t have the option to upload files. They can only browse for resources on FME Flow.”
Solution: In your Flow App settings, ensure the setting ‘“User Can Upload” is enabled.
After that, the app should look something like this:
(but I'm not sure this wil work for a folder..)
marta.podsiad
Forum|alt.badge.img+9
Hi, I have tried the ‘Use can upload’ option but it does not read the folder saved on the laptop
  • July 7, 2025
It does look like if you have a folder parameter, you don’t get the option to browse the file system to select a folder. I’m not sure whether this is by design or not...
alexbiz
Forum|alt.badge.img+31
  • July 7, 2025
keller
  • November 20, 2025
Out of trial and error i was able to solve this problem by zipping the files as ​@alexbiz suggested.
