FME Flow - Error Communicating with FME Server host localhost
  • August 20, 2024
  • 0 replies
  • 412 views
rzel24
Forum|alt.badge.img+7
Hello,
So the following issue that was suppose to be fixed with version 2018.1 and onwards is not completely dealt with
The issue seems to point to an error related to UNC paths using international characters when adding Network Resources as pointed out by this article:
https://support.safe.com/hc/en-us/articles/25407651730573-No-FME-Engines-Available-After-Adding-Network-Based-Resource
According to the article this error was fixed from 2018.1 onwards. However I found out that using a space in the UNC path will cause a similar error (if not the same) and the only way to fix it is to remove the Network Resource with the space in their UNC Path.
I’ve tried with different versions and so far the error shows up even on 2024.1.
This UNC path generates the error:
  • \\seerver\Customers\Data In
When the above UNC path is added to the Network Resources, the system is able to recognize the path and creates the respective folder in the Resources (granted you need to have the right permissions for the network folder in order for it to work). If you change to the System configuration or Backup Menu you won't have any issues at that time. The error pops up when the services are restarted (specifically the FMEFlowAppServer service). After the restart of the services, you are still able to access the Network Resource but if you go to the System Config or Backup Menu you will get the error pop up like the image above.
To fix the error you have to remove the Network Resource with the space in their UNC Path and restart the FMEFlowAppServer again (although I suggest restarting all the services to make sure everything starts up properly).
Although the error only shows when you go into the System Configuration or Backup & Restore menu options in FME Flow app, it also prevents you from running jobs as there is no communication with the Engine.
