Possibility to convert Catia V5 R21 (.catproduct, .catpart) into DWG in FME??
  • September 9, 2013
  • 54 views
franco69
Is there any possibility to convert Catia V5 R21 (.catproduct, .catpart) into DWG in FME??
Best answer by david_r
it isn't listed as one of the formats officially supported by FME, but I suggest that you forward your question to Safe to get the full details.
David
  • September 9, 2013
David
