I have a geometrycollection type KMZ. And I want to import it to ArcGIS. Could anyone show me how to convert it without losing attribute? Thank you
Use the Google KML reader and write with the appropriate ArcGIS writer. What format do you want to write to? (shape / gdb / sde)
Can you share a KMZ?
