ListExploder output a feature?
  • July 26, 2016
  • 63 views
Hi I have a list generated from pointonareaoverlay (and can see the list in the inspector) but when I use Listexploder it fails as a fatal error but can see its trying as the number of records increases any suggestions?
ListExploder_<Rejected>(TeeFactory): ListExploder_<Rejected>: Termination Message: 'ListExploder output a <Rejected> feature.'
  • July 26, 2016
solved it switched off the the termination option under "rejected Feature handling" for rejected features, so just need to review what features it didn't like
