Send feature through transformer one at a time ?
  • May 27, 2016
  • 560 views
lifalin2016
Forum|alt.badge.img+40
Is it possible to halt the normal data flow (preferably with a transformer), and ensure that a certain transformer receives and processes one feature at a time before the next feature is provided to it ? Some sort of "semaphore" or "street light" functionality ?
I have a custom transformer that works perfectly, but its logic is only valid on a single feature.
Plan B is to redo the logic, but if the above is possible, it would be much simpler.
Cheers.
Lars
Best answer by jdh
When I've had to process a single feature at a time in a custom transformer I've added a unique id attribute (counter), published the Parallel Processing Group-By as a published parameter and set it to the uniqueID.
Note if you have a lot of features, you need to keep the parallel-processing level set to No-Parallelism, because windows has a hard limit on the number of sockets that can be opened simultaneously by a single process.
Also depending on the complexity of your custom transformer, the overhead of the parallel processing is more costly than the savings of running in parallel.
  • May 27, 2016
Hi
For non-blocking transformers it is already so: only one feature is treated at a time.
Does your custom transformer use blocking transformers and/or Group By's, maybe?
One workaround could be to move your custom transformer to a separate workspace and call it using the WorkspaceRunner. That way only one single feature is processed at a time. Just be aware that it will take a fair bit longer to run the workspace, as starting and stopping FME for each feature creates a lot of overhead.
David
jdh
  • May 27, 2016
gio
Forum|alt.badge.img+15
  • May 28, 2016
another method is to use a custom transformer and indexes.
Synchronising the inedex with input you can have a object feed to the custom and after processing within the custoim raise the index. etc.
  • October 4, 2023
This fixed my issue.
For me, the leap was to look at the transformer's parameters to find Parallel Processing and Group By. Also, I added a FeatureHolder before the custom transformer and set Group Processing > Group By to create the counter attribute.
